Hello, If any of you would like to get actuator insertion point on valves? Background is well known @ all. But I'll explain it this short. If you have created a valve from DN10 to DN250 this optional one manual-, a pneumatic-, a mechanical- and or a hydraulic actuator. You have to define a actuator for each valve size in Plant 3D. The reason is that the drive is always created at the valve center. But in reality are only 3 or 4 actuator sizes for each valve type available, and these connect on a actuator flange. I want that all valves are extended by an actuator insertion point. Here the drive is to connect and, if possible, the drive should be rotatable! If you miss this important function so say it now.
Who knows nothing has to do anything
Hard-working people aware of their surroundings fit.
Lazy people adapt their environment to itself.
