Solved by dave.wolfe. Go to Solution.
Not on that property. A pipe run component isn't an item you can insert, it's a parent class. If the program worked that way, every component would have the same size (all are under the pipe run component class). Why are you trying to acquire a size in the 3D model?
I was trying to plug the "Size" property of an item (tee, reducer, etc.) into a custom added property of the same item via "Acquisition". Is this not possible? I've tried several variations with no luck. I can copy the value from one prop to another with a .NET function but wanted to use an acquistion to make it automatic.
No, AFAIK you can't acquire properties from the same items. You can create calculated properties however:
http://www.pdoteam.com/2013/07/complex-line-numbers-in-isometrics/
Unfortunately, the Size property is defined using a Callback which means that the value is generated via code and not stored in the database. You will have to use the api to get the property at run time.
Thanks for the help David!
