AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Access "Matching pipe OD" of both ports on a reducer
3 REPLIES 3
635 Views, 3 Replies
Is there a way to access both Port 1 and Port 2 OD of a reducer in Data manager? It seems one can only locate Port 1.
I would like to be able to get a value in my BOM something like this:
OD1 76.1 x t / OD2 60.3 x t
Or atleast be able to access it through export to an .xls-file and then merge them.
It's not accessible through editing Long description Style in Spec Editor either.
Regards
Mikael
Tags (1)
3 REPLIES 3
Reply from Win Hung Tam:
"Hi Mikael, i think this is still an open issue. You can try export the catalog to catalog builder (excel format) and fix the description in excel. Then recreate the catalog."
//Mikael
dave.wolfe
Our extended field plugin makes these sizes available:
http://www.pdoteam.com/store/pdo-extended-fields/
Rather, it does the nominal sizes.  What is the matching pipe od being used for?  I've not seen that in a report before.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
in reply to: dave.wolfe
We use OD and wall thickness when ordering pipes and fittings here in Sweden, that's why it would save us time accessing this info.
”Boost
