Hi everyone,
I'm working with AutoCAD P&ID and I want to customize the layering settings for my P&ID drawings. I need that every service has it's own layer, so that way I can see (say) the whole Cooling water system in the P&ID.
I could do this as I normally do it in AutoCAD, picking each line and selecting the layer I want from the layer pulldown menu, but since AutoCAD P&ID automatically collors and layers the slines I draw, I want to know if there is a way to customize this automatic layering, i.e. that the layer (and/or color) of a PipeLineSegment is automatically set up according to any property of the PipeLineSegment (like service, or spec).
I know this can be done with P3D, but I need it in P&ID.
Any thoughts?
Fabián Becerra
P&ID layers are stored in the projsymbolstyle.dwg in the project folder. You have to modify the layer used in the symbol settings under the P&ID Class definitions.
Well yes, I can see that, but that way I cannot automatically have multiple layers for the same line type.
P&ID has defined some line types, for example Primary process style, or Secondary process style, or Insulated style, and if I do what you suggest I will have all my Primary lines in the same layer, but I don't want this. I have multiple chemicals (for example acid and anhidrid) that are both Primary (they are not utilities), so I have multiple services (for example AC and ANH) and I want to have them in two separate layers, not in the same Process layer (as for default).
I hope I've been clear... 😕
There is no way to have the layer change on the fly. However, I know several clients who just made specific class for the service. So under primary, you could add a class call AC and have it go on one layer, and another class called ANH and have it go on another layer.
