AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
90 Degree Elbow Incorrect Showing in the ISO drawing
19 REPLIES 19
Message 1 of 20
Ahmed1081975
2419 Views, 19 Replies
Hi Autodesk Support,
I have an issue for generating Isometric Drawings,
I have line with 90 degree elbow showing wrong direction
For more clarification Refer the attached file.
Ahmed Helal
19 REPLIES 19
Message 2 of 20
Arun_Kumar_K
in reply to: Ahmed1081975
It's with 2014 or 2013
Message 3 of 20
Ahmed1081975
in reply to: Arun_Kumar_K
Both versions
Message 4 of 20
mikael
Isn't it supposed to run from North to South?
//Mikael
Message 5 of 20
Ahmed1081975
in reply to: mikael
This not my issue my issue the Elbow in the Isometric Shown Wrong in the Drawing
Ahmed Helal
Message 6 of 20
Arun_Kumar_K
If you save the drawing in 2013 to 2010, then if u open in plain autocad 2010 only this issue will come, wat u do, open the drawing in plain autocad 2013 then save in 2010, u won't face problem.
Message 7 of 20
Ahmed1081975
Thanks for Your Reply, my default Setting is saving drawing in 2010
Ahmed Helal
Message 8 of 20
batone79
Check your Isometric Symbol (Acad Block) From your Project Setup.
Should be something like this.
Message 9 of 20
Ahmed1081975
in reply to: batone79
Thanks Very Much For your Reply, the point is coming some places with correct direction and another places incorrect
This not solve the problem the problem in the Isometric.XML fine but where I can't find
Ahmed Helal
Message 10 of 20
Arun_Kumar_K
Don't use weld gap, redraw the line without weld gap. Issue is there with use of weld gap in plant 3d, if it solves Pls. Let me know
Message 11 of 20
Ahmed1081975
Thanks For Your Interesting, Just i can't understand what do you mean weld gap?
Ahmed Helal
Message 12 of 20
Dan.Scales
Hi Ahmed,
Is you pipe model drawn at high coordinates?
If so, try moving it closer to 0,0 and recreate the Isometric.
Dan
Dan Scales
Message 13 of 20
Arun_Kumar_K
Please see the attached pic, remove the check box against weld gap, redraw and you will get the output.
Message 14 of 20
Ahmed1081975
in reply to: Dan.Scales
Hi Dan Welcome Back Long time,
I will assuming it will work after moving the plant, in this case the coordinate it will show in the generated isometric wrong so is that real solution
Ahmed Helal
Message 15 of 20
Ahmed1081975
Thanks very much Kumar,
I appreciated your assistant to try solve my issue,  your concern to uncheck for the pipe gap I have already by default as Uncheck still I have the proplem and up till now Autodesk they can’t solve ?
Ahmed Helal
Message 16 of 20
Dan.Scales
Hi Ahmed,
If this is caused by high coordinates the only workaround is moving to lower coords.
This is something that has been logged with our developers.
Dan
Dan Scales
Message 17 of 20
Arun_Kumar_K
Can u copy a problematic line and save in a new project file and upload here, I ll examine and let u know. If u can't upload here, please send to my email I'd arunkumar.k@thermaxindia.com
Message 18 of 20
Hi @Ahmed1081975 , @Dan.Scales
Was this ever resolved? I have the same issue, but only seems to occur with certain users.
The co-ordinates of the pipe don't make any difference, even with one end of the line on 0,0,0 some of our users have this issue.
Graham
Message 19 of 20
nikele
in reply to: graham.harperNEV5L
hola, alguien resolvio este problema?
Message 20 of 20
graham.harperNEV5L
in reply to: nikele
Hi @nikele ,
The pipe spec I was having this problem with was one I had created with my own endcodes, but I hadn't updated the PLANTENDCODES of the other users to match what I had set up on my own machine - once I did this it solved the problem. Our shared content folder is on a network drive, but I had forgotten that PLANTENDCODES (I had just started using Plant 3D) isn't stored in the shared content folder. Hope this helps.
Graham
”Boost
