Hello everyone,
I'm new in using the 3D module and I have some problems building a Tetrakaidecahedron.
It has 14 faces (8 regular hexagonal and 6 square).
The basic side of the figure is 4mm and the tickness is 0.5mm.
To simplify the work is it possible to parametrize the dimensions?
For example I want to set for the side l=4mm, and changing this value all the linked dimensions are modified.
Thank you in advance for your kind support.
Have a nice day.
Marino
are you trying to do this in Plant 3D?
DarrenP
That would be fun to build out of pipe. I wonder if we have wyes with the right angles...
