AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
3/4" Olets look like 2" pipe on 2" pipe . Why??
4 REPLIES 4
celeste56
458 Views, 4 Replies
Hi,  Can someone look at this and tell me what I am doing wrong?  I am placing olets from the autodesk catalog on 2" pipe.  They look like olets when taken from the catalog, but when attached to line turn into the same size pipe as the line.
4 REPLIES 4
phwatso
in reply to: celeste56
Check the settings for the branch table in the piping spec.
celeste56
in reply to: phwatso
Thank you for the reply.  I tried to change the branch chart several times a couple weeks ago.  What happens is the branch chart says what I am selecting isn't valid, see png.  It gives an option to select a valid branch, and the only valid branch is a stub-in.  Please see png.
Thanks!
phwatso
do you have a 2" x 3/4" olet in the catalog/spec?
celeste56
Here is a pic of the spec.
”Boost
