Hi, Can someone look at this and tell me what I am doing wrong? I am placing olets from the autodesk catalog on 2" pipe. They look like olets when taken from the catalog, but when attached to line turn into the same size pipe as the line.
Thank you for the reply. I tried to change the branch chart several times a couple weeks ago. What happens is the branch chart says what I am selecting isn't valid, see png. It gives an option to select a valid branch, and the only valid branch is a stub-in. Please see png.
Thanks!
