Is there ANY way to be able to select the pipe/fitting then assign the tags....
I am having issues getting PDO Teams BOM creation tool to work with 2015 ( It acutally works compared to autodesks BOM utility )
Having used the CreateBom utility from the PDO team, I guess I am spoiled with a functioning BOM program.
Being able to select the pipe/fittings I want to tag.. is great. makes everything easy to organize. Just attempting to use the BOM thing that autodesk put out is just frustrating.
John.
Solved by dave.wolfe. Go to Solution.
Using it a bit more.. even more frustrated.
issues inclue
difficulty changing the precision ( I don't need 4 decimal places on the length of pipe ( in inches ))
difficulty changing the colour of the text - some is blue some is black ( same table )
some of the table lines are missing.
is all or nothing for tagging pipe/fittings.
again. I seriously hope it is just frustration and not simply horribly written BOM tables and annotation.
Hello Dave,
I'm searching for BOM functionality for our ortho drawings and have been very frustrated with Plant 3D 2015 Ortho Bom functionality.
For starters, the The Ortho View Bill of Materials tool forces me to pick a viewport to establish a source for the BOM. That's fine, but then I'm stuck with the BOM this procedure gives me. I cannot get to any query or programming behind the BOM to customize at all. I have several reasons for needing to tweak the OTB BOM. One is that I may want to show equipment items in my BOM which the OTB BOM doesn't. Also the OTB Bom groups bolt sets by pipe diameter not bolt lenth, so I'll have different boltsets grouped together, which makes no sense. Another thing (which may be a pipe dream - no pun intended- would be to have Bom on a sheet by itself and still be able to use the "BOM Annotation" bubbling feature.
If I create my own BOM using report creator (which I have done) It's better, however, I cannot then use the BOM Annotation feature, so if my model changes and thereby my item numbers shift in the BOM I created, then my manual bubbling will be all off.
I heard your company has developed a BOM app that actually works for real world designers, if this is true i would be interested in it. I checked PDO site and autodesk exchange but did not see. Would appreciate your expertise in this area.
Jeff Heisler
Plant 3D 2015 Implementation Contractor
Seven Seas Water
Tampa, FL.
863-838-8039
jheisler@7seaswater.com
it only works for upto P3D 2014. 2015 needs a new utility.
This is the main reason I havn't migrated to 2015.
John.
