AutoCAD Plant 3D General DIscussion
Distinguished Contributor
DJPiper
Message 1 of 5 (809 Views)
2012 Isometric
809 Views, 4 Replies
10-21-2011 02:13 PM
There is this Line Number Appears beside the extracted isometric, how can we change the format? or maybe if i want to turn it off, where's the control for it?
Another thing i've been playing with the continuation text hoping to get a a full drawing number which consist of a combination of properties + user defined text. for now Plant 3D defaults is only giving Line number Tag. so far, no success. Anyone who done this?
Thanks!
Valued Contributor
JRPalmer
Message 2 of 5 (797 Views)
Re: 2012 Isometric
10-21-2011 08:07 PM in reply to: DJPiper
I figured how to turn it off. (there may be an easier way.
If  you go to your iproject folder, open up isometric, open up the desired ISO style, open ISOconfig, find the following statement and delete (or modify)
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
DJPiper
Message 3 of 5 (786 Views)
Re: 2012 Isometric
10-22-2011 10:23 AM in reply to: DJPiper
yes, your right man. thats where the control is. opening it on xml editor and by deleting the word Line Number or changing the line format from 0 to 1 will turn off that annotation.
i wonder what will be the the set up if i want this annotation to show up in this format, and if this is possible?
         SIZE-SPEC-SERVICE-NUMBER-INSULATION
Product Support
jason.drew
Message 4 of 5 (572 Views)
Re: 2012 Isometric
02-22-2012 01:44 PM in reply to: DJPiper
You might want to check this table for reference. It explains the XML values for the line number scheme:
AutoCAD Plant 3D 2012 - Isometric Configuration
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Valued Contributor
neonade
Message 5 of 5 (423 Views)
Re: 2012 Isometric
04-13-2012 02:04 AM in reply to: DJPiper
Did you have a chance of modifying this annotation on the isometric drawing?
I have a hard time dealing with it.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
