Has anyone had any success with using the new 2011 Spec Editor function, "Convert External Specs and Catalogs"?
It converts .CSV files (which is what I have) to catalogs or specs, but the online documentation says nothing about how to setup the .CSV file for import. The top level document says these new features are for importingfrom AutoPLANT specs or catalogs. So are there any AutoPLANT experts out there that can help with the file format that AutoPLANT exports to?
http://docs.autodesk.com/PLNT3D/2011/ENU/filesPSC/WS73099cc142f48755-751de9951262947c01c-36dd.htm
Hi Jason,
Excellent question. I think the linked White Paper will help. If you have any further questions, please let me know.
the file is available here.
Joan Robins
Sr Technical Writer
Autodesk Plant Solutions
Joan,
Thank you so much! That's just what I'm looking for.
Hi, it´s possible convert external specs from Autoplant to Acad Plant 3D 2010.?
I read white paper and i can´t see from file menu option convert.
can i convert external specs only from Acad Plant 3D 2011?
Hi
Read your Whitepaper and try it to import a easy ELBOW like in your whitepaper, Autocad import the file but if i open the Spec i cant see my ELBOW
Could you send/upload the csv Files in the whitepaper for testing, and see who the structure must be?
here my little File
I also try to create a catalog with the csv-import functionality. In a small sample I created the required column "CLASS_NAME_DEF" and one entry with the class “AT_PIPE”, which is a part of the standard configuration. The spec editor creates the catalog but it is empty.
I try it with the Plant 3D Version 2012.
Have anybody in the meanwhile get a small sample which works?
Attached you will find my sample.
