AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
2011 Ortho Annotation Options
3 REPLIES 3
721 Views, 3 Replies
I would like to just use the Size and Line # when I annotate.  I only have these options available.
Full Line Number Callout [Size-Line Number Tag-Spec]
Insulation Callout [Insulation Thickness-Type]
Line Number Callout [Line Number Tag]
Nominal Size [Size]
Oval Tag Style
Pipe OD [Outside Diameter]
Size and Spec Callout [Size-Spec]
Tie-In Point [TP-xxx]
Is there any way to manipulate this for just Size and Line # callout?
3 REPLIES 3
PeterQuinn
Yes,
You can customize the annotations that are available using Project Setup. Get started by right clicking on the project name in the Project Manager and selecting Properties.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
awerning
I described how to add an Elevation annotation here:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Plant-Generation/td-p/3153432
Should be the same process for what you want.
in reply to: PeterQuinn
Thank you for the help.  One of our Cad Managers figured out that there is a setup under Plant 3D Class Definitions under the Pipe Run Component Annotation.  Under there you can make blocks or modify existing annotations to your liking.
”Boost
