I would like to just use the Size and Line # when I annotate. I only have these options available.
Full Line Number Callout [Size-Line Number Tag-Spec]
Insulation Callout [Insulation Thickness-Type]
Line Number Callout [Line Number Tag]
Nominal Size [Size]
Oval Tag Style
Pipe OD [Outside Diameter]
Size and Spec Callout [Size-Spec]
Tie-In Point [TP-xxx]
Is there any way to manipulate this for just Size and Line # callout?
Yes,
You can customize the annotations that are available using Project Setup. Get started by right clicking on the project name in the Project Manager and selecting Properties.
I described how to add an Elevation annotation here:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Plant-Generation/td-p/3153432
Should be the same process for what you want.
Thank you for the help. One of our Cad Managers figured out that there is a setup under Plant 3D Class Definitions under the Pipe Run Component Annotation. Under there you can make blocks or modify existing annotations to your liking.
