AutoCAD Plant 3D General DIscussion
Valued Contributor
blorich
Message 1 of 6 (405 Views)
2 different computers show 2 different images
405 Views, 5 Replies
10-03-2012 07:52 AM
We have a file on a network that opens and looks different depending on the computer we open it with.  There are a couple different pipes, steel members and other plant 3d items.  We are using 2013.  When I open the .dwg, the steel and other things are not in the correct location.  When the other guy opens it, it shows all the peices in the same area.  We checked and we are both in the same file.  When we open it in Navis works, it shows that the peices are scrambled.  Anyone have any ideas? why the same file looks different?
dave.wolfe
Message 2 of 6 (397 Views)
Re: 2 different computers show 2 different images
10-03-2012 09:43 AM in reply to: blorich
Can you post screenshots?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Contributor
blorich
Message 3 of 6 (333 Views)
10-08-2012 04:58 AM in reply to: blorich
The first image is what the one computer see's and the second image is what the other computer see's.  The guy who moved it see's the top image and think's that everything he moved looks correctly.  When I open the file I see that not everything moved correctly, and that only somethings moved. Including that when he moved things, even Plant 3D created equipment got messed up, the tank on the bottom right corner ended up moving the cylinder and 1 head, and left the other head in its original location.
We thought we found a solution and that the hardware acceleration was not turned on, but after a couple hours it started happening again.
Valued Contributor
blorich
Message 4 of 6 (305 Views)
10-11-2012 01:18 PM in reply to: blorich
Anyone else have this problem yet/
Valued Mentor
dennis
Message 5 of 6 (284 Views)
10-12-2012 06:26 AM in reply to: blorich
Did y'all try updating the graphics card driver from Autodesk driver list?
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Valued Contributor
blorich
Message 6 of 6 (237 Views)
10-18-2012 06:07 AM in reply to: dennis
@Dennis, yes we updated his graphics card.  unfortunately we have not been able to re-create this problem with anyone elses computer. So it's just one guy so I think a re-format is required.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
