AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Railing Handrail Set to PIPE2STD Shown As Square Tube
3 REPLIES 3
kschu1
1849 Views, 3 Replies
I've selected PIPE2STD in Railing settings, but when I draw the rail it shows as square tubing.  Any help on why it does this?
3 REPLIES 3
h_eger
in reply to: kschu1
PLANTSTEELSETREP Changes the model representation of structural objects. R. Hartmut
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
kschu1
in reply to: h_eger
Thanks for the solution!  Your attachement helped me understand the various setting options.
Where are the settings to fininsh the intersection of the toprail and post intersection (see attachement).  Also is it possible to have the end of pipe finished with a pre setting as well.
h_eger
in reply to: kschu1
to point 1:
Where are the settings to fininsh the intersection of the post and toprail intersection.
Please check installation I do not have this problem.
Pic: 2013-07-22_2205 is Plant 3D Structure
to point 2:
So is it possible to have the end of pipe finished with a pre setting as well.
sorry not in Plant 3D Structure.
See image 2013-07 22_2210.png-this comes from ASD 2014
r.
Hartmut
Hartmut Eger
Senior Engineer
XING | LinkedIn
”Boost
