I have problem with inserting my valve, see the attachment.
I have create complete custom Pipe spec and also the valeve is custom create. I select end type and facing as FF in pipe and FL and FF facing for valve. But there is still problem to insert. Also Auto flange does not working.
Solved by m_madrzak. Go to Solution.
Hi Valve should have the same End Type "FL" for both ports (sometimes not but in Youre situation better to do it like that)
Next check Youre Facing, Valve must have the same that seperate flange, last is pressure insert same value for Valve and Flange.
Remember that Valve have 2 ports and You must check both.
PIPE dont need "FF", PIPE shoul have "PL" End Type for stell.
When Ypou do it like this everything should works fine
let me know if u have any problems with it
Regards
Thank you for your answer.
I have soleve the problem, so that I leave facing on the valve empty. In pipe facing I still have FF. But now its working.
I have another question. Now I need also threaded valeve. And I need some treaded socket which will connect valve on one side and welded to the pipe on the other side. Do you have any idea how to do that?
