AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P3D 2012: ISO Breaks Unconsistant
2 REPLIES 2
225 Views, 2 Replies
I just tried to generate ISO for for sections which are identical in parts, orientation and sizes... all 4 ISOs are being generated in one shot, and all four ISOs end up with breaking points at different locations.
this looks very  unprofessional and requires a lot of manul clean up.
anyway to control braking points if not get things to all fit in one ISO and do not break.
2 REPLIES 2
If you use 2012 version is posible to desactive break points, and force iso in one sheet. To configure this you can enter in "Production ISO" select lines and this window press button "Advance" in the next window select the option which you want.
again, like a number of other options that we were able to select in the 2012 version, you can select it, but it doesn't actualy do it... a lot of those functions are bugged.
”Boost
