I am due to start a new project for the pulp & paper industry using thin wall st. Steel metric bore tube & fitting eg 100mm bore x 1.5mm wall = 103mm o/d. Looking at the din pcat that comes with p3d everything is geared up for std matching pipe o/d connections eg 114.3mm. Is there a pcat available or has someone already produced a pcat to suit this thin wall tubing & fittings? It seams a lot of work to create a new pcat before I can undertake any piping - help would be appreciated.
Thanks N Regards
Gary
