AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO - Symbol not display correctly
3 REPLIES 3
Arch_art
960 Views, 3 Replies
I am trying to create a iso, in the pipework, I have placed a Nipple. Nipple is defined as
TYPE=COUPLING, SKEY=NRSC; Which make it on the iso drawing. But problem is, instead of showing the block "nipple" accordingly the IsoSkeyAcadBlockMap, it shows a block call "placeholder". Now, I don't know why it is doing this. The only thing that I can think of is the Type is not quite right. So I tried Fittings, Nipple. It doesn't even work. Is anyone knows this?
Also, where I can find the TYPE definition? Is there a list which tell you what fittings should be considered as what TYPE in Plant 3D?
3 REPLIES 3
Arch_art
in reply to: Arch_art
It display properly now. I don't know why. It seems like Plant 3D need to think a little while. Or I need to restart Plant 3D. I am not sure. Any one can confirm this?
I sitll like to have the TYPE list if any one knows this.
dave.wolfe
I've found it frequently doesn't like the space after the comma between the type and the skey so:
TYPE=XXX, SKEY=XXXX is bad
TYPE=XXX,SKEY=XXXX is good.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Arch_art
in reply to: dave.wolfe
Thanks, Dave
This does fix the problem I have. Interesting !
”Boost
