AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
copy from catalog to Catalog
7 REPLIES 7
Message 1 of 8
Ahmed1081975
726 Views, 7 Replies
Hi Autodesk Support Team,
how Can I copy items from Catalog to another Catalog, and same Issue for Specs
I tried May Time Copy from Catalog and Pest but not Appered like there no action
Please Help
Ahmed Helal
7 REPLIES 7
Message 2 of 8
dave.wolfe
in reply to: Ahmed1081975
http://www.pdoteam.com/2012/02/copying-between-catalogs-for-autocad-plant-3d/
You can do a similar thing for specs while on the spec tab.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 3 of 8
Ahmed1081975
in reply to: dave.wolfe
Thanks Dave,
 These Steps I was made but i discovered my problem, I was open two Spec Edit 2 Times and i was try to copy from one to the other one witches wrong i have to
open only one Spec editor.
anyhow thanks Again
Ahmed Helal
Message 4 of 8
Hi Ahmed,
Currently the solution which Dave has sent is only possible for catalogs, not for specs. I have created here a case for our development department.
Best regards
Bernd
Bernd G.
Senior Product Support Specialist
Message 5 of 8
Thanks Bernd
Message 6 of 8
Yes you can copy from one spec to another in the same Spec editor session.
http://www.screencast.com/t/Hb46BnEo0
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 7 of 8
Hi Dave,
I did run into an error when I tried the same steps. Thoug about it as an issue. Now I have tested it again on a different machine and there it works as it should work.
Thank you for pointing this out.
Bernd
Bernd G.
Message 8 of 8
Please mark my post as the answer if it answers your question. Marking answers helps other find solutions faster. Thanks!
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
