Good day, All,
I wish you everyone a wonderful holiday season.
I'm simply curious: is it feasible to link two sizes with differing specifications?
Essentially, I want to know whether it is possible to join or link a 100NB Stainless Steel Pipe with a 110NB PVC Pipe. So, is it feasible to customize the specification to allow connections of different sizes? For instance, the HDPE Spec specifies 11NB instead of 100NB, and I want to link this to 100NB Carbon Steel. Is that achievable?
If so, would you kindly provide a means for me to do that?
Solved by h_eger. Go to Solution.
Dear @b.mabena ,
Unfortunately, your pipe class designations mean nothing to me. Normally, connections on the pipe side are possible without further ado as long as the nominal diameter is identical in both pipe classes.
For flange connections, the nominal size, pressure class and raised face should be the same.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
