I am using Plant 3D 2014. I have inserted a part from an online catalog and turned it into equipment. When I right-click on the new equipment to select "Add Nozzle" the cursor jumps back to the standard cross-hairs and the command line prompts me for a new command, as if I never selected anything to begin with. Any help would be appreciated. I am not recieving any error messages when this happens.
have you tried suing "PnPLocalDataCachePurger" ??
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Thank you for the advice. What ended up working was that I had to explode the part down to its components and then create the equipment from there. Then, for some reason, the "add nozzle" command worked like a charm. This method worked for two more parts that were also exhibiting the same problems.
