Is there a true color option for the printed documents in VT allowing for color prints of paths?
The colour and line style of every line/element of the path is fully editable and changeable. The swept path’s elements can be set by Properties->Reports:
For Ground Conflict Reports:
The contours are currently drawn at hard-coded intervals 50mm or 2in apart. The contours are coloured as follows:-
More than 100mm ground clearance: {nothing}
Between 50mm and 100mm ground clearance: green
Between zero and 50mm ground clearance: yellow
Between zero and 50mm ground penetration: orange
Between 50mm and 100mm ground penetration: magenta
More than 100mm ground penetration: red
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
