AutoCAD P&ID General Discussion
1 Kudo
Post 1 of 2
Valve Tag Format
249 Views, 1 Replies
03-20-2012 12:02 PM
I'm trying to set up a Valve Tag Format so that the valve will aquire the line size (Top) and the users will be able to manualy enter a valve code (Bottom). I have no issue aquiring the line size but I am struggling with the valve code. I want to be able to use the same valve code several times because obviously the same type/size/spec of a valve will be used hundreds of times in a project...problem is I keep getting the duplicate valve code error. I can't find the proper Tag Format to accomplish this. Please help:smileyhappy:
Product Support
55 Kudos
Post 2 of 2
Re: Valve Tag Format
04-06-2012 12:58 PM in reply to: Exfacto3
Tags as setup to contain unique values for items in the database records. You can use the default, "Valve Code" property (or make a new selection list for it) to enter/select codes that can be used over and over again.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
