AutoCAD P&ID General Discussion
Active Member
Jawhk
Message 1 of 3 (512 Views)
Valve symbols insert as dots?
512 Views, 2 Replies
08-30-2012 01:08 PM
We have been working on a project for nearly a year and only recently have run into the following. In certain PID drawings the valve symbols have been replaced with dots. When a valve is inserted from a pallet it will show up on screen until the tag information is input at which time it reverts back to a dot.
We have been able to copy valve's from other sheets and they copy over fine.. Until you assign a tag (refreshing the symbol) at which time it reverts back to a dot.
Has experienced this issue? Anyone's ideas as to a resolution?
Product Support
quentin.contreras
Message 2 of 3 (454 Views)
Re: Valve symbols insert as dots?
09-04-2012 08:30 AM in reply to: Jawhk
Have you tried the SYNCHSTYLES command? At the command prompt type SYNCHSTYLES, give that a try and see if that solves the problem.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Product Support
quentin.contreras
Message 3 of 3 (436 Views)
09-06-2012 11:30 AM in reply to: quentin.contreras
Did you have a chance to use the SYNCHSTYLES yet?
Quentin Contreras
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
