AutoCAD P&ID General Discussion
craig.wood
Message 1 of 5 (692 Views)
Vale Tag Sequence Number Displays "000" on Every Valve
692 Views, 4 Replies
03-26-2012 09:17 AM
My goal is to create a valve tag that will be unique project-wide, that contains a valve tag sequence number that increments by 1 (starting with 101). I have set up everything I can think of to make this happen, but every time I place a valve, everything displays correctly except that the tag sequence number generated is always "000" for every valve. And when I place a second valve - the same thing happens, and I am not given a duplicate tag warning.
Please help!
I have created the following valve tag as follows:
...and the Project Field setting under "Number" contains the following information:
Further, I have matched the exact same properties on my valve tag annotation.
Lastly, on my test drawing I have tested the AutoGen properties to both blank fields, and Last Valve Number 100, increment by 1, but get the same result regardless.
Thanks in advance!
I figured out the answer to my problem.
It turns out that the root of the problem was that I couldn't even access the "Assign Tag..." command from the right-click menu (by right-clicking on one of my valves).
I ended up finding the answer in a different thread:
http://forums.autodesk.com/t5/AutoCAD-P-ID/Assign-tag-is-not-availlible/m-p/3086982/highlight/true#M2643
Thanks again!
craig.wood
Message 2 of 5 (689 Views)
Re: Vale Tag Sequence Number Displays "000" on Every Valve
03-26-2012 10:15 AM in reply to: craig.wood
Follow up...
After playing around with the settings a little bit more, and the only other thing I can get to generate instead of "000" is "."
Product Support
jason.drew
Message 3 of 5 (667 Views)
03-30-2012 02:17 PM in reply to: craig.wood
Hi Craig,
Please refer to this AU whitepaper for more information about configuring autonumbering and tags:
AutoCAD P&ID Customization: Everything from Tags and Annotations to Symbols
It was written for AutoCAD P&ID 2009, but nearly all of the information in the document is still applicable to the newer releases. The main thing that has changed is the way symbols are setup from 2012 on.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
craig.wood
Message 4 of 5 (664 Views)
03-30-2012 03:00 PM in reply to: jason.drew
I'll check it out...
Thanks Jason
craig.wood
Message 5 of 5 (654 Views)
04-03-2012 11:17 AM in reply to: craig.wood
http://forums.autodesk.com/t5/AutoCAD-P-ID/Assign-tag-is-not-availlible/m-p/3086982/highlight/true#M...
Thanks again!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
