AutoCAD P&ID General Discussion
New Member
darryl_parsons
Message 1 of 3 (439 Views)
Using the same tag on multiple drawing
439 Views, 2 Replies
05-09-2011 07:50 AM
I have a tank that is tagged and I want to use that tank on multiple drawings because it has several services going to it (ie. bilge, ballast, vents and sounds). It is not an option to put the tank and all the services going to that tank on one page.
So is it possible to use the same tank with a tag on multiple drawings?
Darryl
isaac960
Message 2 of 3 (427 Views)
Re: Using the same tag on multiple drawing
05-10-2011 04:24 AM in reply to: darryl_parsons
The short answer is yes.
Normally AutoCAD P&ID wob't accept double tag numbers, if however you have both drawings open P&ID then assumes you have a reason to double tag. P&ID will pop-up 'Tag already Assigbed' then asks you what to do, you can either enter a different tag number or assign this tag which is already in use. The double tag numbers will then be linked and P&ID should recognise them as being the same piece of equipment.
New Member
darryl_parsons
Message 3 of 3 (416 Views)
05-10-2011 08:05 AM in reply to: isaac960
Thanks... Worked perfectly.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
