AutoCAD P&ID General Discussion
Active Member
0 Kudos
Post 1 of 9
Unknown Run Time Error
758 Views, 8 Replies
01-20-2013 09:01 AM
Hi All
I have a problem with the AutoCAD 2012 P&ID software.
Everytime I try to create a new drawing for a new project I get a JIT error coming up with the message at the bottom of the screen as follows:
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Can anyone help me with this problem?
Regards
Ryan
Valued Contributor
21 Kudos
Post 2 of 9
Re: Unknown Run Time Error
01-21-2013 05:59 AM in reply to: ryanmcneil01
To disable Just-In-Time debugging by editing the registry
  1. On the Start menu, search for and run regedit.exe
  2. In the Registry Editor window, locate and delete the follow registry keys:
    • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger
    • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\DbgManagedDebugger
  3. If your computer is running a 64-bit operating system, delete the following registry keys also:
    • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger
    • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\DbgManagedDebugger
  4. Take care not to accidentally delete or change any other registry keys.
  5. Close the Registy Editor window.
Active Member
0 Kudos
Post 3 of 9
01-21-2013 12:41 PM in reply to: georgeendrulat
Thanks for the reply.
I am running windows 7 64 bit and found the first file to delete but cannot find the other three files you have listed.
Regards
Ryan
New Member
0 Kudos
Post 4 of 9
01-24-2013 11:32 PM in reply to: ryanmcneil01
I also have this problem, it has left me stuck unable to use your product
Active Member
0 Kudos
Post 5 of 9
02-16-2013 10:07 AM in reply to: ryanmcneil01
Anyone else have a solution to this problem as the above did not work and I still cannot use this program......
Active Member
0 Kudos
Post 6 of 9
02-23-2013 09:07 AM in reply to: ryanmcneil01
Anyone from Autodesk willing to answer this question and try to help me solve this problem?
Valued Contributor
1 Kudo
Post 7 of 9
02-23-2013 04:56 PM in reply to: ryanmcneil01
He is telling you to delete registry keys not files. I had a lot of trouble when I first installed it too. I had to remove all my previous .NET installations and re-install the latest one and reinstall P&ID then it all seemed to work OK.
Active Member
0 Kudos
Post 8 of 9
02-24-2013 12:39 PM in reply to: kennethmjones
I have deleted these files:
But I cannot find the other two files.
Valued Contributor
1 Kudo
Post 9 of 9
02-24-2013 03:30 PM in reply to: ryanmcneil01
its probably a good thing you can't find them since he is saying you should delete them anyway.
what is the latest version of .NET that you have on your machine I wonder?
I have .NET Framework 4 extended and the.NT framework 4 client pack and it works fine. before I installed AC i had all kinds of other .NET nonsense installed and ACAD had all kind of problems. Thats all I know about this kind of issue.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
