AutoCAD P&ID General Discussion
Rave.Tam
Message 1 of 13 (475 Views)
Silent ExportToAutoCAD command
475 Views, 12 Replies
11-03-2011 12:25 AM
I'm trying to write a script to batch export P&ID drawings to autocad and i use this command "-exporttoautocad".
However, this command will initiate the aec export to autocad command. If i run "exporttoautocad" one time (click cancel in the dialog box), close it ,and reenter "-exporttoautocad" command, it will work.
is there any way i can use the silent command directly? Running out of options here, we have around 100+ drawings in each project and its too time consuming to export one by one.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Active Member
derek.jarvis
Message 2 of 13 (383 Views)
Re: Silent ExportToAutoCAD command
03-29-2012 05:10 PM in reply to: Rave.Tam
Sorry to resurrect an old post - but did you find a solution for this?
Employee
TomislavGolubovic
Message 3 of 13 (380 Views)
03-29-2012 05:42 PM in reply to: derek.jarvis
-exporttoautocad works (in 2012), its all command line driven, is that what you are after?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Active Member
derek.jarvis
Message 4 of 13 (373 Views)
03-30-2012 02:19 PM in reply to: Rave.Tam
I had success with this command - but I am unable to write a batch script with it.
When I open drawings with the "open" command and a network path none of the project commands work. Is there a different command I can use that will have it recognize the project and allow me to ExportToAutocad?
Employee
TomislavGolubovic
Message 5 of 13 (369 Views)
03-30-2012 03:09 PM in reply to: Rave.Tam
What kind of script? VBA, or AutoCAD?
Tomislav Golubovic
Active Member
derek.jarvis
Message 6 of 13 (367 Views)
03-30-2012 03:15 PM in reply to: Rave.Tam
Either LISP or the .NET API would be fine for me.
Employee
TomislavGolubovic
Message 7 of 13 (349 Views)
04-02-2012 05:40 PM in reply to: derek.jarvis
I know in VBA it would be pretty easy to loop through a directory and maybe do the ThisDrawing.SendCommand function?
I am yet to test and double check it works as I think it might
Tomislav Golubovic
Employee
TomislavGolubovic
Message 8 of 13 (347 Views)
04-02-2012 05:51 PM in reply to: TomislavGolubovic
Just found a script I had written for this a while ago. Its a VBA script that you input a folder and what you what to append at the end of the filename, and it does a loop through that folder and exports them to plain vanilla autocad files.
Tomislav Golubovic
Active Member
derek.jarvis
Message 9 of 13 (343 Views)
04-02-2012 10:56 PM in reply to: Rave.Tam
Can you share this script, or at least the snippet of how you opened the file? I've written .Net libraries before that could batch through drawings. But,  like I mentioned earlier in the post, if I open the drawing with the normal AutoCAD method, it does not have access to the P&ID commands.
Employee
TomislavGolubovic
Message 10 of 13 (341 Views)
04-02-2012 11:04 PM in reply to: derek.jarvis
Yeah, you would have to run the scripts inside P3D (or P&ID).
I'll PM you
Tomislav Golubovic
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
