AutoCAD P&ID General Discussion
Roxana-Elena
Message 1 of 6 (743 Views)
Rotation of Instrument Bubbles not Possible
743 Views, 5 Replies
10-25-2011 02:03 AM
Is possible to get a fast answer for my following problem:
I create a new instrument bubble and bring it to Project Setup as any other custom symbol. I set the attachment points and the annotation format. I set the "Rotation on insert" to "Yes". I bring it to tool palet. I insert the bubble, gives me the posibility to rotate but when I release it comes to horizontal position.
I create an empty bubble (without any annotation) , follow same procedure as previous. I insert it and after releasing it everything is according to needed rotation angle.
I have attached the editor block view for the instrument what I use in my project. I suppose the problem cause is the too long annotation format. But this I can't change.
Is there anyone able to help me?
Thank you in advance
Roxana
Valued Contributor
Heckmeck
Message 2 of 6 (688 Views)
Re: Rotation of Instrument Bubbles not Possible
11-16-2011 06:42 AM in reply to: Roxana-Elena
I have experienced the exact same problem.
Would be great if someone can test it or give a hint.
gschimmi
Message 3 of 6 (528 Views)
09-12-2012 11:54 PM in reply to: Heckmeck
Hello
is there some new knowledge for that problem?
I have to rotate the bubbles in a project :-(
thx
Guido
Plant3D 2014 German
WIN7
Valued Contributor
Heckmeck
Message 4 of 6 (476 Views)
09-25-2012 06:25 AM in reply to: gschimmi
The way I did it, was to create a already rotated symbol and add it as a second symbol for your instrument.
Then you can place your instrument, do a right-click, and choose the rotated symbol.
gschimmi
Message 5 of 6 (473 Views)
09-25-2012 06:44 AM in reply to: Heckmeck
OK, I'll go the same way..
Plant3D 2014 German
WIN7
Lucas75
Message 6 of 6 (244 Views)
04-09-2013 09:38 AM in reply to: Heckmeck
I see this a 1,5 year old post...
Has annyone found a solution for this problem yet?
why is it always horizontal?
there should be an option to rotate it i guess??
Somethimes when an instrument is added, you just do not have enough space for it.. espacialy when you have "wide" instrumentsymbols with a  6 digits loopnumber...
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
