AutoCAD P&ID General Discussion
Valued Contributor
Heckmeck
Message 1 of 3 (254 Views)
Report Creator - Filter properties shown
254 Views, 2 Replies
04-04-2013 04:33 AM
Hi Everyone!
I am trying to create a report with the report creator.
In the query editor on the left side, I choose the classes I would like to show in the report.
But I would like not to show all of the properties, since we have very much of them.
How can I exclude a single property from my query? (in the query editor, lower right column)
I appreciate your help!
craig.wood
Message 2 of 3 (236 Views)
Re: Report Creator - Filter properties shown
04-04-2013 02:49 PM in reply to: Heckmeck
The properties displayed in your query are all based on what properties you have in each class within your project setup. If you don't want to see them in Report Creator you have to delete them from your project setup. I don't think this is what you are trying to accomplish. Set your query to only show the specific classes or sub-classes that you want to display in your report by clicking on "Edit Report Layout". From there you can specify which properties you want to display in your report. I would suggest using the Report Wizard to accomplish this.
This document may help tell you what you want to know. It's a very extensive and helpful document regarding how to use the Report Creator.
http://dl.dropbox.com/u/5456278/AutoCAD%20P%26ID%20-%20Report%20Designer%20Help.pdf
I hope this helps!
Craig
If my post answers your question, please click the "Accept as Solution" button.
Valued Contributor
Heckmeck
Message 3 of 3 (229 Views)
04-04-2013 11:04 PM in reply to: craig.wood
Craig, thank you  for your answer!
As you might have noticed, I opened another thread dealing with an error message called "PnpCompletionStatus.NameIsTooLong". This message is displayed when I click on the "test query result" button.
So I can't get any further than this step!
I wanted to filter out the properties which seem to cause this error. Now I noticed, that the error is even displayed when I select only classes which have only the standard properties of the program. (eg. in my case nozzles)
I hope Autodesk can help me with this error.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
