AutoCAD P&ID General Discussion
0 Kudos
Post 1 of 14
Publish always fails
837 Views, 13 Replies
08-10-2012 08:54 AM
Publish always fails. Is this a known problem?
Hi Dan,
I started looking at the system variables for AutCAD P&ID 2013 for publishing. I tried setting PUBLISHCOLLATE to 0 instead of the initial value of 1. That seems to have done the trick. I've been able to publish using the same old page setups that I've been trying since AutoCAD P&ID 2013 was installed. All sheets publish without errors. Publish seems to fail after the first drawing when PUBLISHCOLLATE is set to 1.
Ken
Product Support
35 Kudos
Post 2 of 14
Re: Publish always fails
08-14-2012 07:11 AM in reply to: aeiken
Could you provide a little more detail on what happens when you use the PUBLISH command along with details of your workflow?
Dan
Dan Scales
0 Kudos
Post 3 of 14
08-14-2012 08:07 AM in reply to: aeiken
Hello, I open publisher, add my drawings to print and select my page setup. It doesn't matter which page setup or print/plotter, they all fail to print ( I have no problem printing from AutoCAD or AutoCAD Electrical). Everyone in the company has the same issue. If I print one at a time there's no problem. If I try to publish one drawing that also fails. The error says DEVICE NOT FOUND. I have attached a screen shot of my file paths. If you set the zoom on the word document to about 200% or 300% you should be able to see the paths. Are we missing anything? Thanks, Ken Miller Instrumentation and Controls AEI | AFFILIATED ENGINEERS, INC. 5802 Research Park Boulevard | Madison, WI 53719 P: 608.441.6665 | F: 608.238.2614 kmiller@aeieng.com | www.aeieng.com
Product Support
35 Kudos
Post 4 of 14
08-14-2012 08:27 AM in reply to: aeiken
Have you set all the page setups correctly in the drawings you are trying to publish?
The screen shot doesn't seem to be uploaded, could you attach it again?
Dan
Dan Scales
0 Kudos
Post 5 of 14
08-14-2012 08:45 AM in reply to: Dan.Scales
Hi Dan,
Yes, all of the page setups are correct. I have attached the paths in a pdf.
Ken
Product Support
35 Kudos
Post 6 of 14
08-22-2012 02:02 AM in reply to: aeiken
Hi Ken,
Please upload a screen capture of the "Plot and Publish Details" dialog so I can see what errors are indicated there.
Dan
Dan Scales
0 Kudos
Post 7 of 14
08-22-2012 08:39 AM in reply to: Dan.Scales
Hi Dan,
The attached plot & publish details pdf shows two plots. The one that was successful I used publish and just loaded one drawing. The other was unsuccessful. I had several drawings loaded, but it was using the same page setup and going to the same plot device as the one that was successful. For some resaon when you load more than one drawing into publisher it can't find the plot device even though I select the same page setup.
0 Kudos
Post 8 of 14
09-07-2012 02:33 PM in reply to: aeiken
Hi Dan,
Any news on this issue? I have a project with well over 160 drawings and growing every day. It needs to be printed atleast once a week every week. It is very time consuming to print these out one-by-one every week.
Ken
Product Support
35 Kudos
Post 9 of 14
09-10-2012 11:10 AM in reply to: aeiken
Could you try setting the BACKGROUNDPLOT variable to 0 and re-test?
Dan
Dan Scales
0 Kudos
Post 10 of 14
09-11-2012 06:46 AM in reply to: Dan.Scales
Hi Dan,
I'm not sure whether you received my reply, but the BACKGROUNDPLOT was already set to 0.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
