AutoCAD P&ID General Discussion
Active Contributor
eiloneng
Message 1 of 10 (1,132 Views)
Problem when exporting to AutoCad
1132 Views, 9 Replies
09-28-2010 06:12 AM
Hello all,
Whe rxporting an AutoCad P&ID drawing to to AutoCad, that tag in dome of the instruments or the labels in the spec change block are rotated 90 degrees.
in order to present the drawing to clients we have to look throughly and edit the Autocad drawing by rotating the tag text.
in a drawing this happens with the specific entity whenever exporting
What is the reason, and how can it be avoided
Jacob Eilon
Employee
lopezjo
Message 2 of 10 (1,077 Views)
Re: Problem when exporting to AutoCad
10-01-2010 04:06 PM in reply to: eiloneng
Hi Jacob,
Can you describe the steps I can use to reproduce this issue?
Jorge Lopez
Software Architect
Autodesk Plant Solutions
Active Contributor
eiloneng
Message 3 of 10 (1,069 Views)
10-02-2010 01:42 AM in reply to: eiloneng
This was simple export to Autocad 2010 of a P&ID drawing.  in the original P&ID drawing thins looked OK
if trying to find rule for this happening: The FQ lies on a mechanical link from the FIT to the FIC and this recieves the numeric tag from the mechanical link.
THis rotation of the tag appeares in a similar situation somewhere else in he drawing.
pdh
Member
pdh
Message 4 of 10 (936 Views)
11-27-2010 03:38 PM in reply to: eiloneng
I have a simular case, where a lot of text is mirrored and/or rotatet when the drawings are exportet to AutoCAD 2010 of 2007 formatet. :smileysad:
Best Regards
Per Damsgaard
NTI CADcenter A/S
Employee
PeterQuinn
Message 5 of 10 (897 Views)
12-03-2010 11:39 AM in reply to: pdh
Thanks for letting us know of this problem. I think we understand what the problem is and have it logged in our system to be fixed in a future version. It would be helpful to get a drawing that shows the problem so we can be sure.
Peter Quinn
Senior Product Manager
pdh
Member
pdh
Message 6 of 10 (888 Views)
12-04-2010 08:10 AM in reply to: eiloneng
How many drawings would you like to have ? and where can I send them ?
Best regards,
Per Damsgaard
Best Regards
Per Damsgaard
NTI CADcenter A/S
nikoR
Message 7 of 10 (556 Views)
04-20-2012 03:48 AM in reply to: pdh
Hello;
So is this problem supposed to be fixed by now? Now, two years after those messages above we still have exaclty similar problems as above using PID2012 when DWG:s exported to Autocad - pls see the attachment. Happens every time to same instruments.
Pls inform is it going to be fixed or is there even any workarounds.
Thank you!
Sfarris2
Message 8 of 10 (489 Views)
05-22-2012 06:45 AM in reply to: nikoR
My workaround is to not insert instrument bubbles on lines and do not mirror them when copying them on the drawing. In my experience that is what causes the orientation to change when exported to AutoCAD. I avoid the problem by inserting the instrument and then attaching the lines to either side as required.
Active Contributor
Keough
Message 9 of 10 (470 Views)
05-23-2012 07:31 AM in reply to: Sfarris2
I've been having the same issue, time and time again, and I think I know why - but it still should be fixed by autodesk.. One of many things autodesk seems to lack interest in addressing properly.
This is my understanding:
The instruments are in essence dynamic blocks. These blocks are given an orientation that auto rotates in autocad P&ID so that it looks correct (but still keeps its base point). When you go to export to regular autocad, P&ID doesn't keep the Instrument oriented as it is displayed in P&ID, it changes it to whichever way it hapened to be changed, if it were rotated or mirrored at any point (impossible to tell in P&ID, as it always shows it as being correct orintation), then it will show it when you export.
My Fix: Just be very careful when copying/moving instruments. If they rotate, rotate them back in-place, otherwise, waste time checking for messed up instruments on every single drawing... This really adds a long time when trying to issue a 70 drawing set...
Rave.Tam
Message 10 of 10 (434 Views)
06-11-2012 06:40 PM in reply to: Keough
attsync should fix the block (on the exported drawing). But do not attsync the whole drawing, because the offpage connector will came out wrong
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
