AutoCAD P&ID General Discussion
Active Contributor
0 Kudos
Post 1 of 5
offpage connector to same dwg
176 Views, 4 Replies
04-11-2008 02:23 PM
Is there any way to use the offpage connector symbol and connect to the same drawing file instead of a different drawing file? We want to do this because then the entire p&id can be in one file, with more than one viewport.
*Jorge Lopez
Post 2 of 5
Re: offpage connector to same dwg
04-15-2008 11:29 AM in reply to: earnold
You should be able to use off-page connectors within the same drawing.
AutoCAD Plant P&ID does not allow jumping from layout to layout via off-page
connectors. Is that what you are doing? In any case, you should be able to
link them but not navigate between them as you would across drawings.
"bumble63" wrote in message news:5902607@discussion.autodesk.com...
viewport.
Active Contributor
0 Kudos
Post 3 of 5
04-15-2008 01:12 PM in reply to: earnold
I think I figured it out. You have the second connector inserted, then connect the first connector to the second using the node on the first.
Active Contributor
0 Kudos
Post 4 of 5
05-23-2008 12:28 PM in reply to: earnold
I tried it again and could not get this procedure to work. Yes, you can insert off-page connector symbols in a drawing but the sheet numbers cannot fill in because they are all in the same file. The workaround I can see is to use an AutoCAD block instead of a P&ID connector symbol. If anyone has a different idea please let me know. thanks
Board Manager
1 Kudo
Post 5 of 5
06-02-2008 04:43 PM in reply to: earnold
There is no restriction on connecting two off page connectors that are in the same drawing, if that is what you are trying to achive. Also, it does show the drawing number in the connector, although the drawing number is same as the current drawing number.
What you won't be able to do is connect two off page connectors that are connected to two ends of one Sline. And this is quite a valid case for not connecting.
Mangesh Kalbhor (Autodesk)
Mangesh Kalbhor
Autodesk Plant Solutions
Autodesk, Inc.
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
