AutoCAD P&ID General Discussion
gschimmi
Message 1 of 5 (628 Views)
Object enabler for PID2013
628 Views, 4 Replies
01-10-2013 12:51 AM
Hello
Is there an object enabler for PID2013 so that I can edit PIDs with AutoCad?
Or is there any other way to do this?
G
Plant3D 2014 German
WIN7
If you can edit P&ID with object enabler, who will buy the software? Object enabler is used to view custom data inside custom object. Unfortunately, there's no object enabler available. However, if all you want is to edit the drawing, export it to AutoCAD first.
you must use the P&ID exporttoautocad command. There's a similar command for AutoCAD but that doesn't work. However, you can only export one at a time.
Rave.Tam
Message 2 of 5 (624 Views)
Re: Object enabler for PID2013
01-10-2013 01:36 AM in reply to: gschimmi
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
gschimmi
Message 3 of 5 (619 Views)
01-10-2013 01:58 AM in reply to: Rave.Tam
Hi
an export via dwg or dxf to AutoCad does not help. You can't pick any symbol and so you can't move or copy symbols.
Plant3D 2014 German
WIN7
Rave.Tam
Message 4 of 5 (615 Views)
01-10-2013 02:31 AM in reply to: gschimmi
gschimmi
Message 5 of 5 (610 Views)
01-10-2013 02:52 AM in reply to: Rave.Tam
This is what I've searched for
Plant3D 2014 German
WIN7
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
