AutoCAD P&ID General Discussion
1 Kudo
Post 1 of 5
No Help menu
171 Views, 4 Replies
06-12-2008 05:29 AM
For some reason I can't get the help menu to load. I have re-loaded AutoCAD P&ID 3 times and everytime I hit either help or F1 it says "Cannot find help file: acad.chm" Does anybody know how to fix this problem?
Tom
Valued Contributor
0 Kudos
Post 2 of 5
Re: No Help menu
06-12-2008 09:08 AM in reply to: tom_breitweiser
Go to "Options", "File" tab. Expand "Help and Miscellaneous File Name", expand "Help File". Make sure the location is correct if not browse to where the file is. This should take care of.
Mike
1 Kudo
Post 3 of 5
Re: No Help menu
06-12-2008 09:57 AM in reply to: tom_breitweiser
What file am I actually looking for to be in that directory because I cannot locate an "acad.chm" anywhere. The file that does show up in that directory is adskpid020.chm and that file doesn't exist either. neither of them exist on my hardrive or the AutoCad disk.
Tom
Valued Contributor
0 Kudos
Post 4 of 5
Re: No Help menu
06-12-2008 11:56 AM in reply to: tom_breitweiser
In your help directory there should be a filed called "acad170.chm" for Acad 07. If your using '08 the number will be 171...172 if your running '09.
Mike
1 Kudo
Post 5 of 5
Re: No Help menu
06-12-2008 11:59 AM in reply to: tom_breitweiser
Thanks Mike. Problem solved.
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
