AutoCAD P&ID General Discussion
gschimmi
Message 1 of 6 (453 Views)
no automatic line breaks after substitution of lines
453 Views, 5 Replies
09-21-2012 01:51 AM
Hi
I have a horizontal and a vertical line. There is a line break if the lines have a different break priority.
When I substitute the line with the higher priority with a line class having the same or lower priority so there will be no more an automatic line break.
How can I fix this?
GS
Plant3D 2014 German
WIN7
Product Support
gersteb
Message 2 of 6 (423 Views)
Re: no automatic line breaks after substitution of lines
09-24-2012 07:59 AM in reply to: gschimmi
Hi Guido,
It works fine on my site. Here is a link for a video to show you how it works here. If you see something different from your procedure, please, tell me. What happens if you have a new project with a new drawing. Do you see the same issue there? What happens if you add a new drawing to your old project? The same here?
http://screencast.com/t/m48BvMV4gwSN
Regards
Bernd
Bernd Gerstenberger
gschimmi
Message 3 of 6 (403 Views)
09-27-2012 04:13 AM in reply to: gersteb
Hello Bernd
it is the same behavior when creating a new drawing in the old project.
it is the same behavior when creating a new drawing in a new project, created from our master project.
it is the same behavior when creating a new drawing in a new project.
Regards
Guido
Plant3D 2014 German
WIN7
Product Support
gersteb
Message 4 of 6 (390 Views)
09-28-2012 07:37 AM in reply to: gschimmi
Hi Guido,
Do you use gaps or loops for the line crossing style? What is the value of the gap/loop width? What happens if you do a REGENALL?
Regards
Bernd
Bernd Gerstenberger
gschimmi
Message 5 of 6 (370 Views)
10-01-2012 01:12 AM in reply to: gersteb
Hi Bernd
I use gaps with 5 mm width. REGENALL doesn't help.
(When I move one of the lines the break will be inserted again.)
G
Plant3D 2014 German
WIN7
Product Support
gersteb
Message 6 of 6 (363 Views)
10-01-2012 02:15 AM in reply to: gschimmi
Hi Guido,
Thanks for the information here. I can now recreate the issue when I use PIP norm, creating two crossing primary line segments and after substituting one of them with 'secondary line segment - existing' the gap is lost. I logged this now to our developemnt department. The workaround here is to substitute it with 'secondary line segment' and afterwards to 'secondary line segment - existing' back again. Then you will see the gap on the right place.
Best regards
Bernd
Bernd Gerstenberger
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
