AutoCAD P&ID General Discussion
rnishimura
Message 1 of 8 (484 Views)
modifying ProcessPower.dcf?
484 Views, 7 Replies
10-02-2008 10:35 AM
In previous versions of AutoCAD P&ID (2007 and 2008) I was able to modify "ProcessPower.dcf" with MS Access. In P&ID 2009 Access does not recognize "ProcessPower.dcf" as a database file. Is it still possible to make manual modifications to "ProcessPower.dcf"?
Ryan
Valued Contributor
mbest
Message 2 of 8 (484 Views)
Re: modifying ProcessPower.dcf?
10-02-2008 05:14 PM in reply to: rnishimura
Ryan, yes you can edit the file. You need a Sql Lite editor to do it.
Mike
*Jorge Lopez
Message 3 of 8 (484 Views)
10-03-2008 06:25 AM in reply to: rnishimura
Mike correctly answered that SQLite is the new
database we use. I am interested to know why you need to manually edit
the database.
Thanks, Jorge
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
In
modifications to "ProcessPower.dcf"? Thanks, Ryan
rnishimura
Message 4 of 8 (484 Views)
10-06-2008 07:57 AM in reply to: rnishimura
I want to add a (space) as the default value for certain instrumentation fields, to avoid the "." from showing where there is no value in the field. The GUI for the project setup in P&ID 2009 does not allow a (space) to be a valid value. Is there a certain SQLite Editor that would be suggested to use?
Ryan
rnishimura
Message 5 of 8 (484 Views)
10-06-2008 08:41 AM in reply to: rnishimura
I am using the SQLite Manager plugin for Firefox to edit the file. However, it appears that I am still unable to put a (space) as a default value for fields when inserting instrumentation symbols. In addition to the Loop Number, I added a Suffix field, which I want to be an optional field. Currently if I leave the Suffix field blank it inserts a "." after the loop number. Then I have to manually go back into the database and add a (space) in the Suffix field to remove the ".". In previous versions, 2008 and 2007, i was able to do this fine. Do you have any suggestions on accomplishing implementation? Is there a way to turn off the insertion of the "." in place of blank fields?
Ryan
Valued Contributor
mbest
Message 6 of 8 (484 Views)
10-06-2008 06:15 PM in reply to: rnishimura
From what little I know about sql queries and from what I found out reading..... Evidently now there has to be a value in the of some type in the column. If not, then programmatically, it adds a period. As a hack programmer, sometimes I require a value for an input. If none is entered, I'll either prompt for a value or create a placeholder for the value so it can be edited later.
I know this doesn't necessarily answer your question, it's the only thing I can come up with.
Mike
Valued Contributor
mbest
Message 7 of 8 (484 Views)
Mike
Valued Contributor
mbest
Message 8 of 8 (484 Views)
10-06-2008 06:16 PM in reply to: rnishimura
Wow!! Besides just about having to reset my @#$%%^^ password everytime, now it's way toooo easy to double post too.
Mike
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
