AutoCAD P&ID General Discussion
jonasroslund
Message 1 of 7 (613 Views)
Leaders to instruments are stuck, cannot be moved
613 Views, 6 Replies
09-14-2012 02:03 AM
When inserting instruments, you can use the L option to attach a leader, allowing the instrument to inherit properties from the pipeline. However, once attached, the point where the leader connects to the pipeline cannot be stretched or moved like other lines can. The instrument stretches, but the point where the leader connects to the pipeline sticks. The only way to move the connection point is to cut out the pipeline, move the pipeline and instrument to the new location and reattach the pipeline to the upstream and downstream pipelines. This cannot be the way it is intended to work.
We've had this problem for years, and I wonder if anyone has found a better work-around.
Please note, this applies to the "built-in" instrument leaders you can insert when the instrument is inserted. It does not apply to leaders inserted manually after the instrument.
Jonas
Product Support
Dan.Scales
Message 2 of 7 (563 Views)
Re: Leaders to instruments are stuck, cannot be moved
09-21-2012 07:28 AM in reply to: jonasroslund
This behavior is considered "as designed".
With regard to the workaround, if you need to move the instrument and its leader it may be a faster workflow to delete the existing instrument and re-insert it rather than breaking and relocating the section of pipe.
Dan
Dan Scales
jonasroslund
Message 3 of 7 (543 Views)
09-23-2012 11:39 AM in reply to: Dan.Scales
If it is "as designed", how come ordinary leaders inserted later are not "stuck" the same way? Are the two really supposed to differ in response?
I would say that a "stuck" leader should be considered as a software design error. What is the purpose of it being "stuck"?
To delete an instrument having lots of data and reinsert it (and reenter the data) is a very time consuming work-around.
Jonas
Product Support
Dan.Scales
Message 4 of 7 (510 Views)
09-28-2012 07:16 AM in reply to: jonasroslund
I understand your reasons for wanting to be able to edit the leader line location on the sline and will log a wish with our developers for this functionality.
Dan
Dan Scales
jonasroslund
Message 5 of 7 (507 Views)
09-28-2012 07:21 AM in reply to: Dan.Scales
Thank you, Dan.
Do you have a public wishlist where people can vote for different features and bugfixes?
Jonas
Product Support
Dan.Scales
Message 6 of 7 (502 Views)
09-28-2012 08:17 AM in reply to: jonasroslund
Yes, you can log them here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Also, the forum post can be used:
http://forums.autodesk.com/t5/AutoCAD-P-ID/User-Wish-List-Items-P-ID/td-p/2627946
Dan
Dan Scales
jonasroslund
Message 7 of 7 (498 Views)
09-28-2012 08:21 AM in reply to: Dan.Scales
Thanks Dan.
Jonas
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
