AutoCAD P&ID General Discussion
New Member
0 Kudos
Post 1 of 7
Exporting text (line numbers from P&IDs)
609 Views, 6 Replies
01-18-2007 01:34 AM
How do I export text from Autocad, preferrably to a CSV or TXT file?
Specifically, I would like to export piping line numbers as labelled on process drawings to form a line list.
I do not have Autocad software but others in my organisation do (2006 version I think) a brief explanation of if and how it is possible would be very useful!
Thanks.
*jamesanderton
Post 2 of 7
Re: Exporting text (line numbers from P&IDs)
01-18-2007 08:39 PM in reply to: mikeadams
Mike,
This may seem ridiculously simple, but have you tried copy / paste from the
edit menu and past special into the other application?
Another way would be to set up the text as an attribute. I don't remember
the command call, but you can export/extract data from an attribute to a
text file! This was possible as early as Version 12, before Softdesk
utilized it in their AEC packages.
Let me know if this helps,
James Anderton
AKA "The AutoCad King"
wrote in message news:5455540@discussion.autodesk.com...
very useful!
Thanks.
0 Kudos
Post 3 of 7
01-23-2007 07:23 AM in reply to: mikeadams
A lisp routine is available at dotsoft.com called txtexprt.lsp. This works fine
*Solitaire
Post 4 of 7
01-26-2007 06:48 AM in reply to: mikeadams
if they were attributed you can export them into Access then import the text
file into Excel. I will try to attach a spread sheet to show how my line
list looks like when it's all said and done. If it's something you're
interested in email me direct if you want.
Money is not everything.
There's MasterCard & Visa.
very useful!
Thanks.
0 Kudos
Post 5 of 7
01-26-2007 07:07 AM in reply to: mikeadams
Attribute Extraction will save attribute data directly into excel. There is no requirement for any other application to run this.
*Solitaire
Post 6 of 7
01-26-2007 07:18 AM in reply to: mikeadams
I guess I'm old school I use Access to customize my data.
wrote in message news:5465055@discussion.autodesk.com...
Employee
0 Kudos
Post 7 of 7
02-08-2007 06:00 PM in reply to: mikeadams
A new software is available from Autodesk called AutoCAD P&ID 2007 which provides tools for exporting line list, equipment list etc. from P&ID, edit in excel and import back into drawing along with a lot of other functionality. Please take a look at this site for more information.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8877989
Siva Thankappan
Product Designer
Autodesk Plant Solutions
Siva Thankappan
Technical Sales, Plant Solutions, Asia Pacific
Autodesk Singapore
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
