AutoCAD P&ID General Discussion
Valued Contributor
2 Kudos
Post 1 of 4
Exclude Objects from Database
501 Views, 3 Replies
08-10-2012 03:46 AM
Hi Everyone,
I have a drawing with several symbols that serve as a caption.
For example in the upper right corner of the drawing, I show some special symbols with a description of them or some line types with their respective explanation.
Unfortunately, these symbols appear in the datamanger, since I added them via die tool palette and they are PID symbols.
I tried to add the caption to the *.dwt (drawing template), but you cannot add pid symbols there. (I produce a crash everythime I try...)
Is there an easy work around, to not show certain objects in the datamanager?
In a way, I would like to make some objects "stupid"
Best regards!
Explode them.
143 Kudos
Post 2 of 4
Re: Exclude Objects from Database
08-10-2012 03:41 PM in reply to: Heckmeck
Explode them.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Contributor
2 Kudos
Post 3 of 4
08-12-2012 10:38 PM in reply to: Heckmeck
Thanks for the trick! Sometimes it can be so easy!
For those you read this: I had to type "._explode" in order to make the explode command work...else I got "unknown command"
Exploding blocks works great here, but I can't explode my pipes (mostly multilines/slines).
I tried with "pedit" but that doesn't work since mine are Slines.
I also tried with "flatten", but my colors will be lost if I use this command.
Do you have the trick for this one, too?
Thanks!
44 Kudos
Post 4 of 4
08-12-2012 11:31 PM in reply to: Heckmeck
blocking those objects (sline as well) will also exclude them from the data manager. But u'll have problem editing the block later because editing P&ID objects in block editor is not supported.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
