AutoCAD P&ID General Discussion
Valued Contributor
hinde
Message 1 of 2 (773 Views)
disconnecting lines
773 Views, 1 Replies
04-04-2007 07:49 AM
How can i disconnect lines from one another so my drawing is not one connect line jumble.
*Jorge Lopez
Message 2 of 2 (773 Views)
Re: disconnecting lines
04-06-2007 01:08 PM in reply to: hinde
If you are referring to how lines are grouped together, you can use the
SLGROUPEDIT to ungroup lines. In the next verson of the software we have
changed selection so that it does not select the entire group by default.
wrote in message news:5541185@discussion.autodesk.com...
line jumble.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
