AutoCAD P&ID General Discussion
Member
kgroskopf
Message 1 of 4 (281 Views)
Creating Typicals and having each item have its own identity in data manager?
281 Views, 3 Replies
06-28-2012 12:37 PM
Is there a way to create "typical" of a piece of equipment that will be used over and over in the project, but each piece of equipment needs its own identity to show up in the data manager and still only show the one typical for that type of equipment?
Kim
Valued Contributor
peter.jansoone
Message 2 of 4 (268 Views)
Re: Creating Typicals and having each item have its own identity in data manager
06-29-2012 01:34 AM in reply to: kgroskopf
Spoiler
try wblocks ?
Peter Jansoone
Plant Design software consultant at Greenock CAD service
Product Support
quentin.contreras
Message 3 of 4 (254 Views)
06-29-2012 04:35 PM in reply to: kgroskopf
As far as Data Management is concerned each piece of Equipment is unique. There are many different variables that are associated with equipment when being used in reporting. So, P&ID treats anything made under equipment as "1" piece of equipment. So, duplication is not an option. However, depending if you don't want or care about information being in a report, there is another option. You could place the equipment in the "Inline Assets-->Piping Specialty Items". For example you have a Process Line starting at a Tank and ending at a Tank. You would add a Tank symbol to the Piping Specialty Items. Add a new Tag Format to just take on the Description of the Tank you created. Add the new created Tank to your palette. Now, when you draw a process line and put a Tank at each end of the process line. The line will read From: TANK, To: TANK. Just keep in mind these Tanks will not show up on an equipment report.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Valued Contributor
peter.jansoone
Message 4 of 4 (72 Views)
06-16-2014 10:50 AM in reply to: quentin.contreras
there is a utilirt called PLANTXDBMANAGER which allows linking objects to an external database. that way you can link through a property with a value like 'pump type1' to a recordset in the extarnal databse to pick up standard values (like a lookup in Excel)
Peter Jansoone
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
