AutoCAD P&ID General Discussion
11 Kudos
Post 1 of 5
Convert to P&ID Object problem
380 Views, 4 Replies
07-18-2012 05:55 AM
when using the Convert to PID Object command it does not allowed you to select items do not have a symbol in project manager?
Valued Contributor
14 Kudos
Post 2 of 5
Re: Convert to P&ID Object problem
07-18-2012 09:04 AM in reply to: thebearjed
I think you'll find that you can only select assets which have a GraphicalStyleName property defined.  I suspect that it looks up the default symbol properties from this symbol - it needs to lookup connection type, tag requirements etc from somewhere.
Andy
Active Contributor
2 Kudos
Post 3 of 5
07-18-2012 10:22 AM in reply to: andy.davis
That is a good restating of the Problem.
The question is how to fix or work around said problem.  In most cases if a graphical style already existed, you would not need to convert-to-P&ID-object.  -And creating an empty block for every class seems prohibitively time consuming and difficult.
Active Contributor
3 Kudos
Post 4 of 5
07-26-2012 08:43 AM in reply to: tgwestbrook
There is no real "fix" for that, because it behaves this way by design. You could create a default block and assign this block to all the "blank" classes.
Not a real solution I know.
Carsten
Product Support
35 Kudos
Post 5 of 5
07-27-2012 01:58 AM in reply to: thebearjed
I will log a feature request with our developers to give the user the ability to create new class symbols using the "Convert to P&ID Object" command.
At the moment you will need to workaround this limitation by creating a symbol for the class before using the "Convert to P&ID Object" to add a new symbol.
Dan
Dan Scales
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
