AutoCAD P&ID General Discussion
thebearjed
Message 1 of 5 (364 Views)
Convert to P&ID Object problem
364 Views, 4 Replies
07-18-2012 05:55 AM
when using the Convert to PID Object command it does not allowed you to select items do not have a symbol in project manager?
Valued Contributor
andy.davis
Message 2 of 5 (363 Views)
Re: Convert to P&ID Object problem
07-18-2012 09:04 AM in reply to: thebearjed
I think you'll find that you can only select assets which have a GraphicalStyleName property defined.  I suspect that it looks up the default symbol properties from this symbol - it needs to lookup connection type, tag requirements etc from somewhere.
Andy
Active Contributor
tgwestbrook
Message 3 of 5 (360 Views)
07-18-2012 10:22 AM in reply to: andy.davis
That is a good restating of the Problem.
The question is how to fix or work around said problem.  In most cases if a graphical style already existed, you would not need to convert-to-P&ID-object.  -And creating an empty block for every class seems prohibitively time consuming and difficult.
Active Contributor
cbeinecke
Message 4 of 5 (331 Views)
07-26-2012 08:43 AM in reply to: tgwestbrook
There is no real "fix" for that, because it behaves this way by design. You could create a default block and assign this block to all the "blank" classes.
Not a real solution I know.
Carsten
Product Support
Dan.Scales
Message 5 of 5 (320 Views)
07-27-2012 01:58 AM in reply to: thebearjed
I will log a feature request with our developers to give the user the ability to create new class symbols using the "Convert to P&ID Object" command.
At the moment you will need to workaround this limitation by creating a symbol for the class before using the "Convert to P&ID Object" to add a new symbol.
Dan
Dan Scales
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
