AutoCAD P&ID General Discussion
Active Member
0 Kudos
Post 1 of 2
Control Valve - leader lines
220 Views, 1 Replies
04-10-2012 11:40 AM
When trying to insert a new control Leader Line itt is locked in ortho on. Is it possible to change a setting to be able to sraw a leader at an angle?
John J
Product Support
55 Kudos
Post 2 of 2
Re: Control Valve - leader lines
04-16-2012 01:50 PM in reply to: johnjpowelljr
I think the only workaround is to press the F8 key to toggle ortho off.
I will submit a feature request to have ortho temporarily toggled off right after placing the control valve (and 45º polar turned on since these are typically placed at that angle out from the control valve.)
Thank you,
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
