AutoCAD P&ID General Discussion
0 Kudos
Post 1 of 3
Control Valve Block Problems
379 Views, 2 Replies
12-18-2012 05:00 PM
Have you guys ever seen anything like this before?  It is only doing this in one particular drawing.  I've audited/compressed/purged/etc.
Product Support
33 Kudos
Post 2 of 3
Re: Control Valve Block Problems
12-21-2012 02:20 PM in reply to: jwedeking00
When did you get the message? Does this happen when you try to place a new control valve? Does it allow you to try to substitute a valve? Does this happen when you place a normal valve as well?
Have you tried to remove the drawing from the project?
1) Close out of all drawings, Remove Drawing from P&ID Drawings
2) Audit Project
3) Close the P&ID
3) Locate drawing in Explorer
4) Rename the drawing file, other than the name it was saved as in the project
5) Open P&ID and Open project and Audit project again
6) Use Open to open the renamed drawing file, select drawing to copy clip (Ctrl + C)
7) Create a New Drawing in the P&ID Drawings and give it the original name
8) Paste (Ctrl + V) the drawing
9) You might get ? next to the tag, just right click to edit tag and ok to close and the ? should be removed
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
0 Kudos
Post 3 of 3
12-24-2012 09:17 AM in reply to: jwedeking00
I copied the drawing and the block still acted the same way.  I removed the drawing from the project and started over and everything seems fine.  Thanks
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
