AutoCAD P&ID General Discussion
Active Member
r.roxana
Message 1 of 8 (343 Views)
Column filters
343 Views, 7 Replies
06-17-2008 09:24 AM
I have some problems setting filters on columns in Data Manager.
I managed to set only filters of type =700 or ='something'.
When I try to use wildcard or '?' I always get invalid filter.
Does anybody know how to set filters containing '?' and '*' ?
Some examples would be very useful.
Roxana
Valued Contributor
bestm
Message 2 of 8 (340 Views)
Re: Column filters
06-18-2008 03:51 PM in reply to: r.roxana
Roxana,
Can you post a drawing or picture of what you wanting to do. I'm not sure I understand.
Mike
Active Member
r.roxana
Message 3 of 8 (341 Views)
Re: Column filters
06-19-2008 12:05 AM in reply to: r.roxana
Hi Mike,
Thanks for reply!
I attached a print screen with what I'm trying to do: filtering the Description column for ='Centrifugal Blower' . And this works.
But I want to filter all the rows where the Description column starts with 'C' letter. In Help is mentioned that '*' and '?' can be used. So I tried: 'C'* , 'C*' and other combinations also, but I'm getting an "invalid query input" all the time.
Do you know how should I set a filter that includes some '?' or '*' ?
Thanks!
Roxana
Valued Contributor
bestm
Message 4 of 8 (340 Views)
Re: Column filters
06-19-2008 09:30 AM in reply to: r.roxana
Sorry Roxana, I can't seem to get it work for me either.
Maybe Mangesh (Autodesk0 can tell us what we are doing wrong.
Mike
*Jorge Lopez
Message 5 of 8 (340 Views)
Re: Column filters
06-23-2008 02:56 PM in reply to: r.roxana
Instead of:
=’C*’
Try:
Like ‘C*’
Thanks to Sasha for his help.
- Jorge
"r.roxana" wrote in message news:5961006@discussion.autodesk.com...
Hi Mike,
Thanks for reply!
Thanks!
Ro
xana
Active Member
r.roxana
Message 6 of 8 (341 Views)
Re: Column filters
06-23-2008 11:29 PM in reply to: r.roxana
Hi Jorge,
Indeed it works that way!
Could you please provide a list of keywords that can be used in filters, along with a few examples?
Thank you!
Roxana
*Peter Quinn
Message 7 of 8 (341 Views)
Re: Column filters
06-25-2008 05:51 PM in reply to: r.roxana
Roxana,
It's using SQL syntax, similar to how the SQL WHERE clause works. I found a
web site (by googling for SQL Syntax WHERE) that has some examples of what
you can do: http://www.w3schools.com/Sql/sql_where.asp
Peter Quinn (Autodesk)
wrote in message news:5964623@discussion.autodesk.com...
Hi Jorge,
Thank you!
Roxana
Active Member
r.roxana
Message 8 of 8 (343 Views)
Re: Column filters
06-25-2008 10:27 PM in reply to: r.roxana
Hi Peter,
Thanks a lot for your help!
Best regards,
Roxana Racz
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
