AutoCAD P&ID General Discussion
Active Contributor
eiloneng
Message 1 of 10 (852 Views)
Changing the name of a P&ID 2012 project
852 Views, 9 Replies
12-19-2012 09:04 AM
Hi All
is there away to cahnge the name of an already running project that contains P&IDs and data
Jacob Eilon
Valued Mentor
ybogdanov
Message 2 of 10 (819 Views)
Yes, is posible. Yo need: 1. Change the name of folder 2....
12-20-2012 12:25 PM in reply to: eiloneng
Yes, is posible. You need:
2. Change the paths in Project.xml
3. Change description and name of project in all dcf files
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Product Support
Dan.Scales
Message 3 of 10 (804 Views)
Re: Changing the name of a P&ID 2012 project
12-21-2012 02:54 AM in reply to: eiloneng
As Yury says in the previous post, it is possible to change the project name.
To edit the name in the DCF files you need to use an SQLite editor of some kind. There are various ones available to download online.
The table that contains the project name that needs to be edited is called "PnPProject".
Please note that doing the name change in this was is officially supported and the recommended way would be to create a new project using the required name and copy the drawings from the old project to the new project.
Dan
Dan Scales
Active Contributor
eiloneng
Message 4 of 10 (724 Views)
01-04-2013 01:32 AM in reply to: eiloneng
Thanks for the answers
1. I could not find in the project PnPProject.dcf file in the project folder (Aurocad P&ID 2012)
I2. Is there an editor you would reccomend
Jacob Eilon
Rave.Tam
Message 5 of 10 (710 Views)
01-04-2013 07:46 PM in reply to: eiloneng
You'll need to modify all the dcf files (iso, ortho and etc) inside the project (4 or 5 of them). Here's a couple of free editor which i recommends on my blog
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Valued Mentor
ybogdanov
Message 6 of 10 (703 Views)
01-05-2013 05:47 AM in reply to: eiloneng
Jacob Eilon
PnP Project is not file of project folder. It's the table which stay in each dcf file. You need to open ProcessPower.dcf file with any SQLite editor and modify the table PNP Project.
Yury Bogdanov
Barcelona (Spain)
Valued Contributor
eljoseppo
Message 7 of 10 (430 Views)
10-25-2013 03:58 AM in reply to: eiloneng
what exactly means edit PNP table? I was following your steps but I cannot find my values (althought I can find names of fields that I'm looking for). All I can find is some kind of definition od the table but not the content of the table.
What I expected is to find my old Project name and then replace it with new one.What am I doing wrong?
(As a matter of fact Im trying to change name of one folder which contains drawings, I'm preety sure that this is the same problem).
Please forgive me if the answer is obvious, this is my first experience with the SQL base.
dave.wolfe
Message 8 of 10 (390 Views)
10-28-2013 05:43 AM in reply to: eljoseppo
http://www.pdoteam.com/2011/11/changing-the-project-name-in-plant-3d/
In your case, I think you are looking at the Design tab instead of the Data tab.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Contributor
eljoseppo
Message 9 of 10 (373 Views)
10-29-2013 04:56 AM in reply to: dave.wolfe
Thanks for the answer.
Do you have SQLite Explorer? On download page I can see only uncompiled files.
dave.wolfe
Message 10 of 10 (313 Views)
11-04-2013 05:50 AM in reply to: eljoseppo
I don't use explorer any more since it doesn't show the guids right. AFAIK, sqlite expert is the only program that is free and shows the guids.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
