AutoCAD P&ID General Discussion
gmalone12
Message 1 of 4 (163 Views)
Changing the directory of a entire project in Autocad P&ID??
163 Views, 3 Replies
11-03-2011 11:21 AM
I have to copy a whole project to a different folder in a clients server. Sowas wondering if there was a easy way to move/change the directory of a Entire project, including all the drawings under the project, without it messing up anything.
:smileysurprised:
-Thansk in advance
*Expert Elite*
Rave.Tam
Message 2 of 4 (156 Views)
Re: Changing the directory of a entire project in Autocad P&ID??
11-03-2011 06:04 PM in reply to: gmalone12
Open all the xml file inside the project folder, and replace the path.
If you're using 2012 version, drawing info is stored in the database, not xml. Drawing should open without problem because it will search the relative path. But the drawing template that you assign to the folder will have problem, you need to fix the path in the database.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
gmalone12
Message 3 of 4 (150 Views)
11-04-2011 05:32 AM in reply to: gmalone12
I'm using 2011 So I would open them up with notepad and change the directory?
*Expert Elite*
Rave.Tam
Message 4 of 4 (140 Views)
11-06-2011 11:55 PM in reply to: gmalone12
yes, better off using notepad++ and use "replace in all opened documents."
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
